460 balancer problems - 460 Ford Forum
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
post #1 of 4 (permalink) Old 06-24-2015, 04:18 PM Thread Starter
ben
I'm having a little trouble with this 460 engine that I just bought. The numbers on the block says its a 70's 460 from a Lincoln but when I got it, it had a unweighted balancer and flex plate on it which made a bad vibration so I'm trying to find out the easiest way to determine which weighted balancer and flex plate I need? I did find a weighted crankshaft spacer would that be a choice to use or not?
ben is offline
post #2 of 4 (permalink) Old 10-13-2015, 04:38 AM
If its a 1970 460 engine it would be internal balance,you just need the standard flexplate and balancer and no external weight.
460 lincoln is offline
post #3 of 4 (permalink) Old 10-13-2015, 06:36 AM
Quoted: 184 Post(s)
460 is right,It shouldn't have a weighted flywheel,or a hatchet spacer behind the dampner,
could be a late model?
do a compression test
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #4 of 4 (permalink) Old 10-13-2015, 09:14 AM
White Lightning's Avatar
Quoted: 62 Post(s)
To realistically figure it all out, you'll have to pull the pan and see what the number is on the second crank counter weight. 2Y's are internally balanced.
White Lightning is offline
