This Ingenious Pass-Through Ratchet And Socket Set is 70% Off - 460 Ford Forum
post #1 of 1 (permalink) Old 02-04-2019, 04:21 PM Thread Starter
Your Bargain Hunter
<p class="p1">When it comes to mid-tier tools—respectable quality offerings that won't the bank like pro-grade stuff will—GearWrench is consistently a go-to brand in the pack, and we just came across one of their more out-of-the-ordinary kits at a significant discount. More commonly known for their quality ratcheting wrenches, this ratchet and socket set maintains that same mantra of streamlining your repair/DIY job.
<p class="p1">Even to the more well-versed wrencher this set might look a little confusing at first glance. Specifically designed for nuts fitted onto longer studs, as well as for bolts on top of an engine bay that have a ball socket for affixing engine covers (See right hand side of turbo coolant reservoir in this video clip), you're basically trading off a larger diameter ratchet head in order to not have to fuss with using wrenches or (if you're lucky) extra deep sockets.
<p class="p1">
<p class="p1">It's also worth noting that GearWrench added a very smart feature to the ratchet in this kit, and one you don't even always see on pro-grade ratchets out there. The flexible ratchet head in this set has a locking function, meaning you can set your desired angle and safely guide your ratchet to its target location—something that will occasionally prove frustrating without a lock, especially when using a heavier socket/extension combination. If we were looking at full-pop retail, the kit runs for nearly $200 (a bit steep, to be frank), but at 70% off you're looking at $83.30. Given the cursing and busted knuckles this kit can save you, we'd say it's worth it if you're looking to add some more specialized kit to your growing tool collection.
<p class="p1">Shop The GearWrench Pass-Through Ratchet And Socket Set Here
WiseGuide Deals is offline
What socket or tool to remove oil pressure sender? audioresearch Engine Tech 5 04-27-2015 04:56 PM
Ball & Socket header bolts keep falling off. MrScharfenberger Engine Tech 19 10-01-2011 09:49 AM
5/16 socket stuck on oil pump drive/in-car oil pan removal help? AndyMarkV Engine Tech 26 05-03-2011 10:05 PM
9/16" lug nuts chrome splined with socket NIB, $64 shipped Behemoth DT The Auction Block 0 06-11-2010 04:51 PM
