460 Ford Forum (https://www.460ford.com/forum/)
-   Engine Tech (https://www.460ford.com/forum/37-engine-tech/)
-   -   Oil in Coolant system (https://www.460ford.com/forum/37-engine-tech/246815-oil-coolant-system.html)
1979_F100 04-13-2019 03:25 PM
I recently herd a ticking noise in the engine so I decided to look into it. Checked oil and nothing registers on the dip stick. Looked in the radiator and seen oil. Could a bad head gasket cause this or is it the block or bad heads?
John F. 04-14-2019 09:06 AM
Sounds like some sort of gasket problem.
J.
1979_F100 04-14-2019 01:01 PM
It has a turbo on it with a 7lb wastegate spring. The heads aren’t studded either as I can see the lower head bolts. When I looked in the radiator I could see the oil and when I removed some it looked to have a fiber like material in it. Assuming that is remains from the gasket.
BOSS 429 04-14-2019 10:43 PM
Originally Posted by 1979_F100 (Post 1662935)
It has a turbo on it with a 7lb wastegate spring. The heads arenít studded either as I can see the lower head bolts. When I looked in the radiator I could see the oil and when I removed some it looked to have a fiber like material in it. Assuming that is remains from the gasket.
DONT NEED STUDS FOR 7 LBS OF BOOST ON A BBF, UNLESS YOUR TUNE IS WAAAAAAAAAAAAAAY OFF AND YOUR KILLING IT
litshoot 04-15-2019 12:51 PM
Hopefully headgasket. If not could be a cravked block, bad turbo. Oil has much higher pressure than your coolant.
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
