460 Ford Forum (https://www.460ford.com/forum/)
-   Driveline (https://www.460ford.com/forum/47-driveline/)
-   -   Switching servos (https://www.460ford.com/forum/47-driveline/246919-switching-servos.html)
1979_F100 05-10-2019 08:49 PM
Switching servos
I currently have an S Servo in my c6. The trans had a b and m shift kit and a 3500 stall converter. I’m going to rebuild the trans here soon do to some slipping in 3rd gear. The shifts are firm and it all seems to work fine except when I’m cruising I notice I have to keep giving it throttle to keep goin when it’s warmed up. My question is should I change to an R Servo is it worth it and what else needs to be changed to accommodate an R servo.
gregaust 05-11-2019 04:09 AM
If you were happy with the shift firmness before then not a lot to be gained. The S has a fairly small apply. There are other factory servo like a D or L or P that work well with bit bigger apply.
Yes the R is even bigger again.
Not quite sure what you mean have to keep giving it throttle, is that really a trans issue?
1979_F100 05-11-2019 02:02 PM
When cruising down the highway it feels like I loose momentum. My rpms don’t change so I give it throttle and I speed up but it feels like the transmission is slipping. If I lay into it hard I can feel something isn’t right, it doesn’t go like it should it will make a pulsing vibration if that makes any sense. It has a 460 with a turbo so when it spools up I have engine power but doesn’t seem to be getting to the wheels.
gregaust 05-11-2019 11:41 PM
What torque converter ? Was it built for the turbo? Sounds a little like the torque might be blowing through the converter .
Assuming oil looks ok ?
1979_F100 05-12-2019 02:25 PM
I bought the truck as is but I looked at the converter through the dust cover and it looks like a standard converter shell not painted like an aftermarket one might be. Is there a way to check if it was built? And the oil in the trans has some fine metallic flakes I noticed on the dipstick
1979_F100 05-12-2019 02:26 PM
The fluid isn’t burnt it’s nice and red like new fluid
1979_F100 05-12-2019 08:23 PM
Would it be feasible to put in a 2400-2600 rpm stall converter in? Would like to be able to drive it in the highway. I think the previous owner built this rig for pulling a sled and never planned on getting out of first gear.
gregaust 05-13-2019 03:46 AM
At this stage a converter change is prob a good move . A stock converter would be struggling to hold the torque with the turbo.
Since the oil is good and assuming there's not excess junk in the pan it's worth a try
thermod 05-13-2019 08:27 AM
I don't know,Greg.The OP said there was some metal on the dipstick oil and from the vague description,the trans might be slipping.You might end up filling a new converter with debris. If it were mine,I would do a refresh before buying a converter. JMO
1979_F100 05-13-2019 11:26 AM
I’m wondering if the metal flakes came from the converter itself from not operating correctly. I have a rebuild kit for the trans so I may as well do it while it’s down. And if I were to change the converter what stall should I put in?
aquartlow 05-13-2019 01:46 PM
I had an issue with my C6 that was just not right at upshift points and had a pulsating feeling while driving steady, I found this carnage that happened to the VB separator plate @ the converter check ball/valve orifice. I mistakenly installed the check ball instead of the valve, the results from that mistake are shown below. The early C6 VB's used the check ball, the later ones replaced the CB with the check valve, probably due to more contact surface area from the valve.
https://www.supermotors.net/getfile/...e/dscf4333.jpg
https://www.supermotors.net/getfile/...e/dscf4334.jpg
https://www.supermotors.net/getfile/...e/dscf4342.jpg
Hope this helps.
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
