2X3 frame backhalf. $1000.00
9 inch FORD Rear end housing and axles go with the frame.
Chassis includes
Battery mount in rear, intergal with frame.
narrowed rear, you can run 14.5 X 33 tires or maybe bigger..
FORD 9" Rear end housing has 33 spline Mosers (AXLES ARE INCLUDED ) Long studs in axles for NHRA requirements.
also has upper and lower coil over mounts, for those DA shocks you want to run. REAR also has a back brace and filler port on top.
Ladder bar rear suspension with all rod ends, diagonal link.
wheelie bar mounts, disc brake rotors and calipers, calipers are late model Chevy.
what this does NOT include:
Rear shocks
no center section
frame rails are 24" center to center. rear is 42" backing plate to backing plate.
Chassis includes
Rear shocks
no center section
