1 - 3 of 3 Posts
I have a full set of eight (8) Sealed Power H535CP .060 over pistons. These were installed, but never fired. They were swapped out and cleaned so they look absolutely brand new. No rings.
Asking $250 shipped.
Here are the specs below from Summit:
Bore (in)
4.420 in.
Bore (mm)
110.744mm
Piston Style
Flat top, with two valve reliefs
Piston Material
Hypereutectic aluminum
Compression Distance (in)
1.752 in.
Piston Head Volume (cc)
+4.20cc
Wrist Pin Style
Press-fit
Pin Diameter (in)
1.040 in.
Piston Ring Thickness
5/64 in. x 5/64 in. x 3/16 in.
Notes
DurOshield® coated piston skirt.
1 - 3 of 3 Posts
