Hello everyone. First time post. I have a 1973 460 and it is backfiring when accelerating. I tried everything to fix the problem but it wouldn’t get any better. I noticed a lifter ticking on the #1 cylinder. I removed the valve cover and intake and one of the pushrods on #1 was very loose. I took both lifters out of #1 and one was shorter than the other. It appears the bottom of the lifter has worn away which is making it shorter. My question is, can I get by with replacing just the lifters or do I need to replace the camshaft as well? I’m just relieved I found out what was causing the backfire. What would you replace? All that metal had to go somewhere which has me concerned. Do you think the wear was caused by the camshaft? Thank you!
Update: After doing some research it looks like I will have to replace the camshaft and lifters. Luckily they come in a set. What camshaft would you recommend? I wouldn’t mind upgrading to another camshaft that will improve performance and give the engine that lope sound everybody seems to love. Would I need new rocker arms and springs? I honestly don’t know where to start. None of these camshaft specs make any sense to me. It’s like reading a different language. Again it’s a 1973 460 with a Holley 750 double pump, HEI distributor, Weiand Stealth intake, headers with flowmasters and everything else is stock. Thanks again for any advise.
