1 - 15 of 15 Posts
1150 gas 3 circuit meatering blocks $450 obo
429-460 roller cam $150 obo used. cam card reads as follows
intake exhaust
valve adjustment .026 .028
gross lift .714 .748
duration at 020
tappet lift 308-5 308-8
open close
valve [email protected] int 26degrees btdc 66degrees atdc
exh 70 degrees bbdc 30degrees atdc
duration at 050 272 280
lobelift 420 440
cam is ground on a 110 lobe center
Sorry its a model 9377. Its the old style with out the flat top. I have pics if you send me your email address.
aa
Certainly clean from looking at the pics
Assume if was properly drained when stored to avoid the varnish type gunk forming inside ???
What part of the world are you located in ??
Im in Pa. Its all clean inside. Just needs someone to use it. My 460 spun a bearing and i dont have the money to fix it.
cam
I am interested in cam.
Do you have any pictures?
what brand is it and how old?
whats your location in Pa. ?
Thanks,
Dave
Discussion Starter #15
The carb is for a dominator style intake but you can run an adapter to put it on a stadard flange intake. I have a adapter that i will throw in for the asking price.
1 - 15 of 15 Posts
