1 - 8 of 8 Posts
-1963 Ford Galaxie 2 door hardtop (Boxtop) set up for 460/c-6
-Crites Fiberglass fenders, inner fenders, tear drop hood, core support, trunk lid, bumpers and brackets
-Plexi glass rear windows and quarter windows
-8 pt roll cage
-Interior is gutted but has factory carpet, doopanels etc
- 16 gal trunk mounted fuel cell, bg-400 pump, with Mallory 5 port regulator
-9 dutchman rearend housing with back brace, 35 spline axles with Stange double ribbed nodular housing, 4:30 gears with spool, fresh brakes, lines
Mallory hy-fire ignition system
-Cal-tracs split mono leaf rear springs with cal-trac bars
-Competition engineering rear 3 way adjustable shocks
-Summit 3 way adjustable shocks up front
-Front disc spindles, rotors brakes from 71 torino with fresh brakes, new lines
-4 steel driveshaft with 31 spline yoke and 1350 u-joints
-B+M pro shifter w/reverse lockout
-Summit high back race seats
-15x10 steel rear wheels with new 29x10.5 mikey Thompson slicks
-15 x 4.5 weld pro star front wheels with new 29x 4.5 mickey Thompson tires
If one decided to purchase with Engine and trans here are some specs on those
557 D1VE block +.080 passenger lifter bores bushed (work done by engine systems in atlanta)
SCAT 4.5 crank
Scat 6.8 H-beam rods
Venoilia forged pistons Compression ratio is 11.1:1 for pump gas
Kasse oil pump
Milodon 8 qt deep front sump pan
Comp xr-292 solid roller cam with thier newer styler roller lifters with improved oiling to the bearing.
Blue Thunder Standard ford port cylinder heads with Manley Nextech springs (i have flow numbers for this if needed)
Crane roller rockers with Jomar stud girdle(s)
Edelbrock Victor intake 4500
Pro-Systems Dominator 1150 cfm Carb built for this motor
Trans is a Broader Performance C-6 with 3500 10" stall conv.
manual valve body
deep aluminum pan
Looking to get $8,000 as a roller minus engine and trans
Looking to get $18,000 complete
Clear/Clean Title
car is rust free and in primer finish, but has minor body damage by the pass. scuff plate area (pic attached)
I can provide video, pics or whatever for engine/trans. I would considr partial trades plus cash for the following items
Car is located in NW Florida
48-52 GMC/Chevrolet 5 window pick-up truck (needs to have good body)
4x4 ATV or john deere gator
Sprinfield M1-A
Complete TIG welder set-up
Call with any questions (850-218-6130)
[email protected]
minor damage from move by pass scuff plate
sale pending on car as a roller, i will make a seperate post or update this one as needed for the sale of the trans and 557
car still available, i'm looking to unload the with the motor (trans has been sold) for 13k obo
looking to get funds together for buying a older pre-emmision freightliner
pm me or call with questions ?
850-218-6130
1 - 8 of 8 Posts
