1 - 3 of 3 Posts
Hey everyone I have some ford 429 460 parts. I recently bought a 1969 and have some parts off it I want to get rid of. This was also the last year for the 460 with a crank driven power steering pump, in 1970 they switched to a belt driven pump mounted on the side of the block. So here's what I got let me know if your interested:
2 stock 4bbl carbs from early 460's- $20 each
2 stock cast iron 4 bbl intakes - $20 each
Alternator brackets - $20
2 stock flywheels - $25 each
Timing cover with crank driven power steering pump and reservoir - $100
cast iron exhaust manifolds, no cracks - $40
2 air conditioning compressors and brackets - $60 each
Stock distributor - $20
Thermostat housing - $15
Dipstick, timing chain cover style - $10
Front pump for a c6 - $25
Stock stall 1.848 pilot torque converter - $70
Block plate for auto trans - $20
Air cleaner in good shape says lincoln continental 460 4v - $15
Let me know if you need anything, my name is Ryan and you can call or text 610- two four six- 8084
I'm interested in your accessory brackets. What side of the engine is the A/C? I need a P/S bracket too, you wouldn't happen to have one of those would ya?
1 - 3 of 3 Posts
