1 - 8 of 8 Posts
The head gasket is supposed to block that passage to force water to the rear first. If the garbage shown blocks coolant flow around the cylinder then you need to address this.
It appears that some cooling system maintenance was overlooked.
SJ
used 2b RHP
:D
ok so now would be a good time to clean out that blockage of crud. I also noticed that the crankshaft doesn't have the external counterweight on it. Will this be a problem?
1973 460's are internally balanced. Spacer is not weighted.
SJ
1 - 8 of 8 Posts
