1 - 12 of 12 Posts
I got bored last year and thought i needed a winter project. Spring is here and it is just like i bought it but with about another grand worth of parts. $3500 OR TRADE
http://www.youtube.com/watch?v=f7JwlBBocuo
87 LX with a fresh 466 Big Block.
460 block Bored .060 over
Roller rockers
ARP rocker studs
Hydraulic lifters
New pushrods
Nitrous Cam
High torque starter
Victor 460 intake
Stock crank redone
Aftermarket forged connecting rods (don’t remember which ones)
Ported and polished factory cast heads
Oversized intake and exhaust valves
Headers with 1.75” primaries and 3” collectors
Full 3” exhaust with x pipe
Twin high flow mufflers
Billet dipstick
Custom made high performance driveshaft
B&M pro stick shifter (Carbon Fiber)
10 AN fuel sender in tank
10 AN fuel line from tank to Carb
Cleanable high flow fuel filter
130 GPH fuel pump
Fuel pressure regulator
Oil filled fuel pressure gauge
Edelbrock 750 Carb (Custom built for this motor setup)
Battery relocated to trunk
2 gauge marine grade wire from battery to starter
Tubular K member
Tubular A-arms
Coil over front suspension
1.5” K member billet spacer
1.5” Billet sway bar spacer
Custom made steering shaft
2.5” cowl hood
Subframe connectors
3 row aluminum radiator with trans cooler
16” electric fan with thermostat control
MSD ignition with rev limiter
MSD Distributer cap
Accel wires
MSD Blaster coil
GT brake booster
Custom E-brake handle
K&N open Air Cleaner lid (not shown in pic)
More New Parts:
All weatherstripping
Windshield trim
Windshield wipers and arms
Wiper cowl
Headliner
Fuel level sending unit
High output alternator
Water pump
Heater core
Battery
Have but not installed:
3:90 gear
8.8 posi unit
8.8 gear install kit
Currently has 7.5 axle, but have everything for the 8.8 except the housing
Custom steering wheel with nitrous buttons
All factory gauges wired in and working (Speedo, Tach, temp, oil pressure, fuel, Amps)
All lights functional (except reverse lights)
Windshield washer and wipers functional
Power steering functional
Brand new fully built C6 trans installed with:
3500 Stall converter
4 gear spider
Ultra wide band
Red Eagle clutches
Full manual reverse custom made valve body by drivetrain dynamics
Trans brake (not hooked up)
Extreme duty external trans cooler
I purchased this car as a project but since that time I have found other things to take up my time! this car needs a new home! What you got to trade?Cash? Ask I may say yes!
Discussion Starter #2
Nothing at all?
jon boats, a pontoon what you got? this has got to be worth something to someone. O well if you got anything other then a project car or a wife we can probably work it out!
I have this I have been prepairing to paint and sell were even on whats been invested. Have all the parts partialy dissassembled for painting needs some finish work.
1 - 12 of 12 Posts
