Hello all - new here and am researching answers for how to upgrade the front brakes. this has the original 4 cyl spindle and brake set up.
I am using an engine plate. I want to go to a tubular K member kit with a arms and coil overs. Will the 4 cyl spindle work and what upgrades can I do to the front brakes? I have four lug wheels and would like to stay with the wheels I have as they are new alum drag lites
Any suggestions to what mfg to go with on the K member kit?
thanks Jeff
Team Z,Maximum Motorsports,UPR,QA1,AJE...spend as much as you want.All have their good points.Check into K member spacers between the K and the body. Keeps the motor lower in the body. Lots of different brake outfits out there but make sure the calipers fit behind your wheels...without spacers.The 4 hole deal is hurting you because there are decent later model 5 hole setups that will work and available for cheap at the U Pick.
