1989 mustang lx hatch. 65K original miles original 5.0 5 speed car.
all work was done by Boschma's speed shop (myself)
everything on this car is 100% brand new never been run once.
mini tubbed
through the floor 2x3 subframe connectors
chromemoly cage tig welded will certify to 8.50
8.8 rear axle narrowed 2 1/4 in. on each side
moser 35 spline axles
moser c-clip eliminators
moser spool
pro 5.13 gear cryo'd
strange coilovers
wolfe double adjustebl uppers
wolfe double adjustable lowers
wolfe antisway bar
wolfe spherical bushings
flaming river kill switch 10 gallon Jaz fuel cell mounted
custom chromemoly driveshaft loop
complete UPR front k-member,a-arm and coilover setup with starnge adjustable struts
flaming river rack
flaming river steering shaft
steeda bumpsteer kit
svo master cylinder can be used with power booster or manual
aerospace drag brakes front and rear with stainless braided lines
complete tubular chromemoly front end in front of the shock towers. no the car wasn't in an accident.
it shaved a ton of wieght and made tons of room as you can see in the pics.
it is setup for a stick and motor plates with a SBF. or you can still use standard motor mounts.
the car still has the main factory wiring for the lights and blinkers. but no injection stuff.
does not come with the wheels and tires.
this car fully loaded with engine,tranny and a 200# driver will wiegh less then 2600#. the hood and hatch are original steel
the entire front clip is one piece removable with some dzuz fasteners.
i'm sure theres more i'm forgetting just please call or email for more pics and with any questions.
the motor and tranny DO NOT come with the car no ignition system or fuel system. and you'll need your own seats as well.
i do have two kirkey drag seat and brand new harness's and the wheels and tires. i will sell it all for the right price but i'm not including them in the rolling chassis.
email me at [email protected] or call 608-346-4015 thanks John
i'm only going to post a couple pics if you're a serious buyer please ask for more if you're just adding to your collection please don't waste my time.
$10,500 may consider trades for ?
Discussion Starter #2
this car is ready for a BBF. even a mild 460 would put this car easily into the 10's
