Good afternoon,
I've come across a vacuum line that is not connected and I need to locate the correct component so I can hook it back up. On the factory vacuum line diagram it appears to be the lone "pink" line that runs from BRV to SOL V. The
top photo appears to be the BRV end. The bottom photo SOL V. The BRV end pops out of the insulator and hooks
into a black rubber vacuum line that was probably installed when the factory one broke. All help is appreciated.
I just did an engine swap in my 91 f350, I replaced my 300k mile engine with a 100k mile engine.
I eliminated all that junk emissions stuff! Thes do not need all that stuff to run and be efficient! I put headers on mine with a cam, lifters swap, new timing chain,oil pump, push rods. The only vacuum line hooked up now is for brakes and heater controls. Engine bay is much cleaner now! This runs way better than it ever has.
Dan
