1 - 12 of 12 Posts
Life throws some curve balls at you some times and I got hit with one this week. I don't know if I can go thru with this or not, but it's my only way out right now. I will list as much as I can remember, there are soooo many good parts on this car. Here's some pics first..
Keith Craft 514 short block, probe pistons, eagle rods and crank, arp bolts
D3 heads, ported and polished, with Comp springs, and guide plates
Comp hardened pushrods
Comp 1.73 roller rockers
950hp carb
610 lift 300/310 dur solid flat cam
Torker 2 intake
Griffen 4 row alum radiator
dual electric fans
D&D mid length headers
Motorsport valve covers
Procomp electric water pump
MSD distributor
Mallory Digital 6 box
ATI SFI Balancer
MSD Wires
A1000 Aeromotive pump & Regulator
-10 braided feed line
-8 braided return line
16 gallon fuel cell with sending unit
Optima battery
Auto Meter Guages and Monster Tach
B&M Carbon Fiber Quarter Stick shifter
C-6 Trans with built valvebody
3800-4200 Convertor
Upr tubular k-member and tubular a-arms
lakewood 9/10
Caster/camber plates
Ft coilover kit
QA1 rear adj coilovers with adj QA1 shocks
Ladder bar setup
9"
Strange Nodular housing
Spool
4:11 gears
35 spline axles
Wilwood Brakes
Weld draglites 15x12 and Jegs 15x4 wheels
Hoosier rear tires and Mickey Thompson Fronts
Fibertrend Cowl hood
12 cage with swing outs on both doors (will cert. to 8.50)
line lock
Removable steering wheel
Racing buckets
CD player
3" exhaust
3" 2 chamber flow masters
All lights, wipers, and heater still work
$10,000 or may trade down plus cash
I have no timeslips yet, feels very strong. With a good set of alum heads, it would be freakishly fast. lol
Interior needs finished, (no carpet, or sound deadening yet)
Paint looks good, but has some dings here and there.
Here's a link to a "project in progress" http://www.460ford.com/forum/showthread.php?t=131914
[email protected] Thanks Troy
Thats too bad you gotta pedal it Troy.:(
Looks like you put a ton of nice work into it.
Good luck with the sale.
Bill
Only the democrats can say the unemployment rate is going down when 230,000 people lose their jobs in July. I guess that is why you are forced to sell it. I am sorry for your misfortune. Keep your chin up.
1 - 12 of 12 Posts
