$19,000
12 point chromoly wolfe race craft cage and cam lock seat belts , 33 spline moser axles and spool,4.10 ford racing gears, anti roll bar , aje k member and coil overs. flaming river rack, transbrake powerglide with ptc 9.5 converter,JW case 1.80 bte planatarys caon ringless super shaft and pump,electric shift, aero space brakes front and rear ,12 inch wide weld wheels on rear , 5s on front,. MSD,with crank triger ,magnafuel 500 fuel pump. steada weight jacker billet aluminum lower control arms ,double adjustable uppers, strange aluminum rear cover with main supports. axle tube braces, aluminum radiator. 4 inch cowl hood. msd power grid controller, new qfx 1150 dominator, 3 nitrous bottles, nos big shot plate. strange 10 way adjustable shocks on front .
A-460 block
TFS 325 CNC heads with tulip ford racing ex. valves
TFS 4500 intake
FX-4711 QFX 1150
eagle 4340 4.300 stroke crank
6.8 H beam eagle rods 2000 bolt upgrade
4.560 bore ross custom 8cc dome pistons with internal milling wt.614 grams
14.1 compession cometic custom 4.620 bore .040 thick
moroso oil pan with kaase oil pump
solid roller bullet cam 280-292 112 lobe sep .786-785 lift
2-1/8 kooks headers with 4 inch collector
601-757-0187
