1995 MUSTANG 408 small block ford victor jr. intake , forged crank, H-beam rods , 2- valve relief SRP pistons soild roller cam , 1050 dominator, msd distributor , msd wire, msd coil, msd 6al box w/ digital retard, electric water pump , aluminum radiator , Aeromotive fuel filter, Aeromotive A2000 fuel pump , Aeromotive A4 4-Port regulator , Aeromotive fuel filter , Brodix Cylinder Heads, 2-Stage Speed Tech Nitrous System , Ultra -Case powerglide Trans / w Pro Trans Brake , TCI Outlaw shifter, Tubular K-member , tubular A-Arm ,w/ adj coil overs , adj caster/ camber kits, drilled and slotted rotors front and rear, sub-frame connected.
REAR:adj upper and tubular lower w/ strange adj rear shocks, rear anti-roll bar, rearend braces, 456 gear. 31 spline axles . this is a 5sec. 1/8 mile car
have more pics HAVE TITLE IN HAND
$12000.00 OBO
IT'S NOT MY CAR BUT I CAN ANSWER SOME QUESTIONS . THE CAR IS IN SELMA ,ALA
334-431-2313 OR 334-872-6072
$12000.00 OBO
