1 - 3 of 3 Posts
I hate to do it, but I don't see myself driving it again.
The good:
1997 F250HD with a PowerStroke diesel.
E4OD transmission.
Limited slip differential.
Has a Class 4/5 hitch along with bed rails for a 5th wheel or gooseneck.
Swapped to an electric fan on a toggle switch after the stock clutch fan crapped out a few thousand miles ago.
Clean Carfax and KY title. I have owned this truck since Nov '01 and 82k miles. Currently has 213k on it. I drove this truck all over the country and it never missed a beat.
It has a new FORD radiator installed along with a new water pump, hoses, and thermostat 2.5 yrs ago. Truck has sat since then.
No rust issues although it does have some minimal rust given its age.
White with a grey center side "stripe"
The bad:
Truck needs the front suspension and steering fixed. Steers like an old school bus.
Injectors need new o-rings.
Brakes need work.
Needs a set of new leaf springs in back as one has cracked one of the inner leaves off at the spring pin bolt.
Needs front tires, as they are showing cords.
No radio will be included, but factory plugs are still intact.
Truck will need to be towed from my house in Lexington, KY, as it is NOT driveable.
Given some elbow grease, this would make an awesome hauler for someone on the cheap.
$4500 OBO
Brian
Discussion Starter #2
Took some pictures...
Never mind the poster sized sticker, some neighbor ratted me out for an inoperable vehicle improperly parked.
Brian
1 - 3 of 3 Posts
