How difficult is this? Does it require removing any of the front bodywork (or worse?)
I have the opportunity to get a 4wd supercab model for low $ with a serious bottom end knock and copper shavings in the oil. (and failed cam phasers)
Thanks!
Jim
If memory serves, the factory recommended service procedure is to hoist the cab & front sheetmetal off the frame with a lift after removing the cab bolts & assorted connections. PM richter69...he should be able to confirm/deny...
It may be possible to do it the conventional way, but it sure seems as if there is a lot of crap that is very difficult to get to because of the firewall.
