Finally cleaning out the garage a little so I thought I would list the following. Note; I'm selling this as a parts lot and do not wish to separate it, also I am asking for local pick up as I really don't want to ship this stuff.
1 N.O.S. Schiefer pressure plate 10" Long Style for Ford Applications
1 pair bare 351c 4V open chamber cylinder heads.
1 set used stock 'Power by Ford' and 1 pair used Moroso valve covers for same.
1 set new in box 'High Port' exhaust plates as used on 1970's 351c Pro Stock cars.
2 used 351c crankshafts 1 is machined 10/10 and the other is stock dimensions.
1 D2AE-CA 351c 4-bolt block. This block has issues, the person I got it from raced 351c's in a stock car and I think this block has a crack in the #5 cylinder, very fixable but at the worst the caps could be moved to another block.
1 C9VE-B 460 block and 2Y crank all of which I believe to be standard.
1 429 4UA crank which I was told came from a low mileage CJ but it does not have a brinell test mark. Some say ALL CJ cranks should have this mark while others dispute this claim, either way non-CJ's , CJ's and SCJ's all used the same casting crank some may have been brinell tested while others were not.
1 D0VE-A 429 2-bolt main block 030 over it was assembled and ran for a very short while then disassembled.
1 set new never used low performance 040 over cast pistons for 429 mounted on low performance connecting rods, pistons have a slight dish.
1 429/460 stock oil pan
1 pair powered by Ford stock valve covers for 429/460
1 mid/shim plate and flexplate removed from the above 460
1 C9VE-9425-A square flange 4V intake
3 exhaust manifolds for early-mid 70's Ford passenger cars
Again, local pick up only and I'd like to sell as a parts lot for $1000.00 or buy these parts AND the Pro Star wheels & tires I have listed for sale, everything for only $1500.00 firm.
I'm located in Va 22602
Need more info or pics? Just ask.
Thanks, Div1Racer
Thanks, Div1Racer
