1 - 8 of 8 Posts
Hello everyone. I have for sale just about everything needed to assemble a strong running 351w. Here's what I have.
1989 block ready to go. .030 over, cam bearings installed, brass freese
plugs
Stock crank 10/10, Clevite bearings, Scat stock replacement bushed rods, fully floating Speed Pro hyperuetectic pistons .030, cast rings, Professional Products damper, C-4 157 tooth flexplate all balanced.
ARP head bolts
Holley Systemax aluminum heads. 1.90 in/1.60 ex. Pedestal mount rocker style. 63cc chambers. .600 lift springs. New in box.
Summit double roller timing set.
Professional Products intake (Performer RPM equivilent)
Hydraulic flat tappet Lunati Voodoo cam and lifter kit. 233/241 @ .050 dur. .538/.560 lift 110 lobe sep.
Compression ratio with this set up is 9:1.
Everything is new never bolted on. Make me a reasonable offer. Thanks. Bruce
Discussion Starter #2
C'mon guys. I gotta make some dough so I can give it to The Mad Porter. LOL :shock: Don't make me use this stuff. I wanna go back to a 460. 8)
This intake was actually bolted on a 393 stroker I built for a friend. It was removed and replaced with a single plane while still on the engine stand. No carb was ever bolted to it nor was any coolant run through it.
$125.00 shipped. Thanks.
1 - 8 of 8 Posts
