1 - 7 of 7 Posts
I have the flywheel off of a 70 Cylcone with 429CJ. I just had it turned before I found out that it wouldn't work with the clutch setup that I am going to. 176 tooth. If it will work for you, make me an offer via PM.
Tim
Edit:
I just measured mine and it had an 11.5" clutch on it.
Tim
Edit:
Thanks for your reply. What kind of psi plate will bolt to it, long or diaphragm ?
When you get the flywheel, get the clutch bolts too. They're a shouldered bolt and you can't get them from Ford.
1 - 7 of 7 Posts
