Hey guys I have some stuff I need to sell.
So I have a 390 FE built and balanced. bottom eng built for 7500 rpm (I was told this, I did not build the motor). .060 over wesco pistons, comp cams kit for valvetrain (not roller, just a hyd flat tappet for a mildly agr street cam), double roller timing chain, polished truck heads. everything on the engine has less than 5000 miles on it, but had the cam broken in incorrectly and it failed. needs a hone, crank polish and new bearings. $650. Comes with everything at this price, all the tin, s code 4bbl intake, your choice of a couple holley carbs, alt, water pump, starter, ect.
460 big block. heads, block, crank, main caps, and rods. $50. (FT3E heads, outof an 80's p/u, needs total rebuild)
TCI 2400 stall converter $150
Worn out C6 transmission. good bellhousing/core $75
I have a pile of holley carbs, and one carter AFB. Some are good for parts only, and a couple look like rebuilders. $10-$40
throw me offers and what not.
Located in washington state, snohomish county (north of seattle).
you have to arrange shipping.
