1 - 17 of 17 Posts
I have the above parts for sale that were used on my 66 Fairlane that I converted to an automatic. Clutch disk is OK but you might want to buy a new disk. The flywheel has some heat cracks that should turn out and be fine. Located in Cincinnati, Ohio. $220 for all. See more pics in the CL link down below...
I have the above parts for sale that were used on my 66 Fairlane that I converted to an automatic. Clutch disk is OK but you might want to buy a new disk. The flywheel has some heat cracks that should turn out and be fine. Asking $325 + all shipping cost. Located in Cincinnati, Ohio.
Can you tell me how many teeth are on the flywheel? Is it 184 teeth?
Also , what year was the engine it came off of?
Was the flywheel a neutral balance for an early 429/460?
RE: Bellhousing, etc...
can you give me the casting numbers from the bellhousing and flywheel (assuming they are Ford). Will you ship ???
Thanks, Rick
No numbers on the flywheel, its bare, neutral balance, no weight. Has a 184 ring gear.
The bell has D71A1 I think but it's very hard to read. These parts were on my '66 Fairlane that had a '72 year 460 in it.
I've been busy moving out of my house for the last two weeks and haven't been back here. Yes the parts are available. Had a few people wanting this stuff but nobody has money. $220 takes it all. I'm in Cincinnati, Ohio 45233.
1 - 17 of 17 Posts
