SOLD Used Lunati solid flat tappet cam and lifters for sale PN: 41610LUN
This cam was bought off a fellow forum member some six years ago. He had put six dyno pulls on it. That is all. I installed this in an engine that was never started or run. I got a deal on a Roller cam so have no use for this one.
Duration at 050 inch Lift 256/266 Int/Ext
Advertised Duration 310/320 Int/Exh
Net Valve Lift with 1.73 Ratio Rockers 0.572"/0.580" Int/Exh
Lobe Separation 108
Valve Lash 0.022 in./0.024 in. Int/Exh
SOLD $125 plus shipping
Set (16) of used double valve springs with damper, steel retainers, and 10 deg valve locks. Were set up at 1.975" and will work with above cam. Don't know whose springs or history. Came on a set of heads I had bought.
$50 plus shipping
Set (16) rocker arm studs. Don't recall brand, but were bought new and only used for mockup. 7/16-20 thread .800" long. effective lenght is 2.100". Base is a 7/16-14 thread .750" long.
$25 plus shipping
Set (16) hardened chromemoly 3/8" .080" wall x 8.600" pushrods. These were bought new and only used for mockup. I don't recall the brand.
$50 plus shipping
Set (8) Manley 3/8" guide plates. These are used, but in good shape.
$25 plus shipping
2 sets (32 pair) titanium Super 7 (8 deg) standard height valve locks. These are used. One set looks good, other set shows some wear.
$50 plus shipping for both sets.
still have the cam?any idea on how much shipping is to fl 32796? do you have pics? does it have lifters? all marked? let me know. thanks
Yes the cam and lifters are still for sale, actually everything listed is still for sale. All the lifters have been kept in order. I will post up some pictures and get you a shipping quote. Thanks Steve
CAM AND LIFTERS ARE SOLD
UPS would be $25 to ship the cam and lifters.
Below are some pictures of the cam and lifters. I noticed some staining on the cam from the cam lube which will not hurt anything. Keep in mind this sat in an assembled engine for about six years.
