1 - 3 of 3 Posts
Here are some pictures of my 429 richter69 and i are building for my 69 cougar
http://i132.photobucket.com/albums/q14/shanecheatham/IM001029.jpg
http://i132.photobucket.com/albums/q14/shanecheatham/IM001030.jpg
http://i132.photobucket.com/albums/q14/shanecheatham/IM000995-1.jpg
It is .030 over wisco dome pistons
c9ve heads ported by the Mad Porter
2.19/176 valves
Cam reasearch solid lifter cam
258/262 @ .50
640/640 lift
Stealth intake with 850 dbl pumper
I am hoping the little booger will run pretty good !!
I built a similar combo a few years back, but I used the TRW flat tops. It had a Cam Reasearch solid with very similar if not the same specs. and C9 ported heads as well. It was in a 67' Cougar with 4.88s out back. It was an all steel, full interior street car. The combo was good for 7.0's in the eighth on motor, and 6.60's on 125 spray. The only problem I ever had with car was trying to keep a C-6 behind it.
R
Guest
I think his c6 will be fine, should be a fun deal when its all together.
1 - 3 of 3 Posts
