1 - 8 of 8 Posts
· Registered
Check this one out guys. 429 out of a F700. Bought the truck, it actually ran fine, but had a ton of blowby. Compression test showed #5 and #6 were dead. Any thoughts what would cause this? Strangely enough, no debris in the oil pan.
Automotive lighting Bumper Automotive tire Automotive exterior Gas
· Premium Member
Detonation likely aggravated by oil contamination of the intake charge.
If the piston tops are mottled like an orange or eroded that is more evidence.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
· Premium Member
You may be right. There was a substantial amount of oil sitting in the intake galley pan.
Oil in the valley pan is normal.
By contamination of the intake charge I mean oil getting past rings and into the chamber where it kills fuel octane.
Custom ground cams
R-H-P.biz
(253)-988-6648
· Registered
Discussion Starter · #5 ·
Got ya. I believe someone was in this engine once before. Every bolt I touched was pretty loose. I am puzzled that there wasn't any debris in the oil pan from that much carnage. Thanks for the pointer Mad Porter!
· Registered
2nd ring seizure. Ring ends butt when hot and seize in the bore, breaking out the lands. Caused by improperly-gapped rings, or excessive heat (including detonation), or some of both. The OP may have found it (or at least the chunks in the pan) and buckled it back together to sell, as those aluminum chunks and ring bits would not migrate anywhere that they would be vaporized. Oddly, bore ring seizures may or may not leave damage or scoring in the bores, but something visible is usually left behind.
While they may have been oddballs the assembler missed, a check of the other ring gaps may give clues. Check the rods for straightness and cracks. If it's been running a while this way, the bearings may show some clues also. Some inspections and forensics on tear-downs helps to find unknown issues. Good luck!
1 - 8 of 8 Posts
