1 - 3 of 3 Posts
I have a few questions. Can I use the 460 fuel injected intake,wire harness and pcm out of a late 80's Ford truck and swap it all onto a 429????If I can do this will the E4OD bolt up to it???Can I swap the 429 to the 460 serp belt set up too???? I have heard that these are the same engine blocks but I want to verify that.
Oh by the way, this will be going into a 88 Bronco 4x4.
Nope...the intake ports in the heads and the manifold ports won't match one another. If you also use the later fuel injection heads it'll fit the 429 but, the compression ratio will be pretty low; 8/1 or so.
1 - 3 of 3 Posts
