Everything needs to go so all prices negotiable.
Text 765-316-1593 for additional info/pictures
429 timing chain cover (two broken bolt holes, should still work)--$25
Alternator off 1979 f250 (460, 60/65 amp, doesn't work but could be used for core)--$10
Camshafts and lifters (one cam is rusty and probably unusable, lifters mixed up on both)--$100
Oil pan off 429 (5qt?)--$25
429 crank (clean one)--$300
460 crank (rustier one, turned 0.010 under once)--$200
Std. bore stock pistons and stock rods from 429 (at least need new rings and two have broken skirts, rods should be good)--$100
.030 over cast pistons and stock rods from 460 (look to be in good shape to me)--$200
4bbl intake manifold off 429--$200
2bbl intake off 429--$100
SOLD---2bbl carb that came with the 2bbl intake--$50---SOLD
SOLD--4bbl edelbrock performer 460 intake--$200--SOLD
4bbl edelbrock 1406 carb--$200
Distributor off 429--$20
Used timing chain set off 429 (1971)--$20
Stock oil pump, shaft, and pickup off 429--$20
Aftermarket oil pump and shaft off 460--$20
Lightweight? Flywheel or flexplate (not sure which) off 429--$100
Engine plate off 429 (not sure what trans, goes woth flywheel/flexplate)--$20
SOLD--D0ve-C heads off 460 (3 angle valve job, don't think they've been ported)--$500--SOLD
D1ve 460 block and main caps (bored. 030 over, needs bored again and cleaned and all that stuff)--$300
