1 - 17 of 17 Posts
Selling some parts that I was going to use
These were installed but never fired
I am going with a different set up....
RPM Modular crank
4.500 stroke 2.200 BB chevy rod journal
Has to balanced with fly wheel, which is not included
RPM rods 600-700 long rods with arp bolts
Probe flat top pistons with rings (4.440 bore flat top)with rings,wrist pins and bearings
$900 obo
pm me
H-Beam Connecting Rod
4340 forged material
H-Beam design for proven strength
Standard ARP 8740 Cap Screws
ARP 2000 Cap Screws standard w/select models
Check tech sheet for your application
Nodular Iron Crankshafts
Perfect for the budget street/strip racer
Available in various stroke and rod configurations
1 or 2 piece rear main seal
Large radius on all journals
Strong castings are perfect for under 600hp
14792-080 SRS Pistons - Ford 532/557 Flat Top -3.0cc (+.080")
Probe Industries SRS Pistons - Ford 532/557 Flat Top -3.0cc SCJ/Kaase
Item Code 14792
Vendor Name Probe Industries
Product Type Pistons
Product Model Sportsman Race Series - SRS
Application SCJ/Kaase
Engine Displacement (cu.in.) 532/557
Engine Family FORD-LINCOLN-MERCURY - Big Block V8
Material 2618-t61 Forged Aluminum
Base Bore (in) 4.360
Stroke (in) 4.300/4.500
Rod Length (in) 6.800/6.700
Compression Height (in) 1.350
Top Type Flat Top
Net Head Volume (cc) -3.0
Deck Thickness (in) 0.250
Valve Pocket Cutters 2.400 I - 0.000 E
Valve Pocket Depth (in) .270 I - .000 E
Weight Without Pin (g) 561
Wrist Pin Diameter (in) 0.990
Wrist Pin Length (in) 2.930
Wrist Pin Weight (g) 151
Pin Lock Type Dbl Spiral
Ring Set # 315-0025
Top Ring Groove Size 1/16 in.
Second Ring Groove Size 1/16 in.
Oil Ring Groove Size 3/16 in.
Top Ring Land (in) 0.340
Second Ring Land (in) 0.160
Bottom Ring Land (in) 0.075
Oil Rail Support Part # 10205
Quantity Sold in sets of 8.
Notes Designed for SCJ-A and Kaase P-51 heads only.
Part Number Cylinder Head Volume
72.0cc
Ford 532
14792-030 13.20
14792-040 13.24
14792-060 13.34
14792-080 13.44
Ford 557
14792-030 13.76
14792-040 13.81
14792-060 13.91
14792-080 14.01
1 - 17 of 17 Posts
