'76 Thunderbird block, crank, rods, pistons
Lunati 61604 camshaft
"straight up" double roller timing chain
ported D0VE heads, machined .020 (hardened seats, Miloden SS 1-piece
2.250/1.725 valves)
PRW 1.73 Stainless roller rockers
CompCams rocker arm studs
Lunati 73815K5LUN valve spring kit
Lunati 80766 Hardened push rods
CompCams 4834-8 guide plates
SVO dual plane intake (Performer RPM)
melling hv oil pump
FRPP fox swap pan kit
full of new 10w-30 full synthetic
high volume aluminum water pump
Holley 850 D.P.
Davis Unified Ignition HEI distributor
MSD6-HVC (MSD 6600)
high torque mini starter
Stock C6 with 3K stall "Monster" torque converter
B&M quarter stick with pistol grip or B&M Composite X shifter (you pick)
$1200 takes it all
cedar rapids, Iowa
319-241-4059
