F250 4x4 1977.5-1979
Does the engine-drivetrain have to be moved forward with the 1977.5 through 1979 F250 4x4 460 conversion frame perches? Also, does the engine sit level? Can I buy everything from you, frame perches, motor mounts? Thank you
460 Frame Perches
Attempted to purchase a set of your 460 frame perches for a 1977.5/1979 F250/350 4x4 on your web site. A message displayed that they were out of stock. When do you think they will be available? Thanks
I have to check to see what I have for the material I am thinking I should be able to build another set with what I have on hand
putting in another order with my cnc guy for more batch cutting
you can get the insulators from my web site I have a link to get them from amazon
the adapter plates that go between the engine and insulators would need to be sourced from your local wrecking yard
1983-1997 460 trucks has these plates
these mounts set the engine in the correct spot so you can use the correct 460 radiator and fan shroud from a 2wd factory 460 truck
correct radiator
http://broncograveyard.com/bronco/i-20604-1977-79-radiator-super-cooling.html
correct shroud
http://broncograveyard.com/bronco/i-20616-fan-shroud-extra-cooling.html
