1 - 20 of 29 Posts
460 Crate Engine - New - Turnkey (w/video)
This engine has been SOLD. (please call if you'd like us to build something similar)
Click HERE to see a video of the engine running on the dyno.
I am offering this engine for only $4950.00.
-test fire, break-in and dyno tune, $850.00
-Ford Motorsport valve covers, $150.00
-750cfm Holley carburator +$300.00
-Distributor with Crane XRi ignition, Crane coil and Ford Motorsport plug wires +$250.00
Turnkey package includes carburator, distributor, ignition, coil, plugwires, and plugs. Everything pictured below is included. Just connect gas and 12V, and you're ready to run.
Street Hustler Package:
-460 Cubic Inches (+.040 bore / 468 CID)
-Holley 3310 750cfm carburator
-Crane XR-i ignition with adjustable rev limiter
-Crane PS-20 coil
-New distributor cap and rotor
-Ford remanufactured distributor
-Ford Motorsport plug wires
-Ford Motorcraft spark plugs
-Ford FL1A oil filter
-Ported D3VE iron heads, new guides, hardened exhuast seats
-New CJ size valves
-Lunati springs, retainers, locks
-Scorpion roller rockers
-Crane stud conversion
-TFS pushrods
-Lunati Hydraulic flat tappet cam
-Lunati Hydraulic lifters
-Cloyes double roller timing chain
-Stainless exterior bolts
-Ford rear sump oil pan
-Melling high volume oil pump
-Ford remanufactured water pump
-Stealth Dual Plane Aluminum intake
-Hyper pistons
-Reconditioned stock rods
-Reconditioned stock crank
-Stock harmonic damper
-King main bearings
-King rod bearings
-ACL cam bearings
-Dyno tested and proven combination
-Premium Unleaded pump gas compatible
-All clearances and specs checked and documented
holy crap thats a flat torque curve. whats the LSA on that cam to give the peak to the torque curve like that? 112? Would you sell it without the carb and manifold?
I will sell without the carb/intake, but you'd be $$$ ahead selling them yourself. PM, call or email me for details. Thanks.
Discussion Starter #12 (Edited)
Engine is painted with early Ford dark blue. (flash in the pictures makes it look lighter).
Discussion Starter #14 (Edited)
wheres the dyno numbers? did i miss it somewhere?
This particular engine made 470 HP and 525 lb/ft with dented/dinged 1-3/4" truck headers and a conservative tune. Similar results should be expected with shorty headers. Full length headers with larger primaries and a more aggresive tune would yield better results.
i am going to take a week and think about it ... i am really interested. there are a few thing i really dont need like the ignition system. i do want the plug wires and plus. i already have msd dist and coil and 6al box.. where would u set the rev limiter??
1 - 20 of 29 Posts
