1 - 6 of 6 Posts
I have almost 3 engines worth of parts that I need to find new homes for. All parts are from good running Ford 460 EFI engines, mainly 91 and 94 model years. You name it and I have at least 2 if not 3 of it. Everything is up for grabs to reasonable offers (see suggested prices +shipping); not trying to get rich, just trying to clear space and see this stuff go to use. Parts located in Leesburg, VA.
I also have a few miscellaneous truck parts for the same years. Here’s a brief breakdown to help. If you’re looking for something and it’s not listed just ask.
1 PCM from 91 Super Duty (F450) manual trans, code: Z2E1 - $75
1 PCM from 94 F250 manual trans, code: SAD0 - $75
3 AC/PS pump brackets - $20 each
2 Alternator/smog pump brackets - $10 each
2 AC delete brackets - $25 each
Crank/water pump pulleys $10 each or $15 per pair
1 New water pump (GMB) - $30
1 New starter motor (NAPA reman) - $30
1 New alternator (NAPA reman) - $30
1 New oil pan - $70
3 cylinder heads (fully assembled): F3TE - $50 each
1 complete short block - $100
1 block disassembled (with crank, pistons, rods in boxes) - $50
3 complete induction setups – only 1 is still assembled – need a manifold, TB, harness, injectors?
2 air filter boxes with hoses to intake - $20 each
2 cold air snorkels (air box to radiator support) - $20 each
3 sets of exhaust manifolds (1 early set, no smog pump ports) - $30 per pair
2 flywheels with good ring gears (manual ZF5 trans) - $20 each
2 radiators – $30 each
3 sets of valve covers - $20 per pair
1 Y-pipe - $20
1 fan with clutch - $20
Other parts:
Pair of F250 XLT fender emblems – normal wear for age - $10
Pair of F250 Heavy Duty fender emblems – normal wear for age - $10
Class 3 trailer hitch (Valley Hitch) - $50
Class 4 trailer hitch (Draw tite) - $75
2 complete sets of front turn signals and side marker lights – 92 to 97 models - $20 per set (set = left and right)
Pair of front coil springs, 97 F250 HD with 7.3 diesel, truck sat up proud, no sag - $50
Front bumper from 97 with black plastic trim – some dings but very presentable - $40
Rear axle from 97 F250, 3.55 with locker, sway bar and new brake pads - $300
Transfer case from 94 F250 that had 460 and ZF5 - $75
Engine run stand - $400 can be seen here: https://www.youtube.com/watch?v=zlh4JIMuIno
I need several items to complete my 429 thunderjet.
1) timing cover with manual fuel pump access
1) main bolt
1) short head bolt
1) set of pulleys for crank and waterpump if they are serpentine and line up on the 429. I plan on fabbing mounts for power steering and alternator.
Let me know how much of it you have and $ it takes to get it to 42518 ky?
May be interested in a pair of valve covers if they aren't center bolt. Thanks
[email protected]
1 - 6 of 6 Posts
