if I had any clue what those things are lol!!!! You’re awesome and I’m thankful for your response. I will google the things you’ve mentioned and look into it!
Hi, I just joined too, and I have a Ford 460 in a boat. I want to caution you about starting and running the engine in a boat, and also doing the tests that were recommended before. When working on a boat engine, the engine bay needs to be vented well by using the blower on your boat. This is VERY important when removing spark plugs, wires, and other ignition components. There will be some open spark, and if there are fuel vapors it could flash-fire. Have an extinguisher nearby too.
Based on your test so far, I would start with a compression test. These engines have weak valve actuator components, and can bend things that are important. The ignition is fairly robust, but it can cause issues with high voltage leakage from the wires, also a fire hazard. Test this by starting the boat in the darkest night, and look for glowing, or very soft sparks flowing from the ignition wire loom at the distributor down to the spark plugs. A common failing of aged wires. It must be very dark when testing.
