1 - 6 of 6 Posts
I have been told that there is a mechanical water pump that allow for a fan on the engine side of the radiator. Does anyone know the part number of this water pump and what applications it was used on? Thanks
I found this on the internet this is the measurement I am looking for: Measure from the top fan hub surface to the water pump mounting surface The industry term for measuring a water pump height is the “hub height”.
The OEM pump you need is C8SE 8505 E,Not too many of them around but a couple of aftermarket pumps on E bay for $250,$300.If you can find a core,Cardone has a rebuild and return deal. The whole thing is not quite as easy as just the pump.Like I said,you need all the pulleys,brackets,balancer,that goes with the short pump.You also need about a 1/4 in shim on the crank spacer.I cut mine off another crank spacer and it works good.
1 - 6 of 6 Posts
