I can tell you what I did to my 351M that sat for 10 years to try and help. Some may think it's over kill or not enough, but it worked for me as it fired on the 3rd turn over.. Now as yours is an EFI I can only offer little advise there. First step pull all the spark plugs and give all of em a good Inspection. Leave em out as your not done yet. Spray a lil WD-40 down each plug hole and put a socket on the crank and turn the engine over a couple of turns. If it won't turn, stop. You've got issues. Pop off both valve covers and check the condition under each one. If it's gunked up or popcorn dry you'll need to do a lil clean up there. Clean up under the valve covers and if you are mechanically inclined enough I disassembled all the rockers clean everything thoroughly and put engine assembly lube on all the points that make contact, don't forget both ends of the pushrods and keep everything together as it came apart. IE rocker assembly and pushrod for intake no1 all stays together. If it's nasty under the valve cover, take the time to clean it when you have the rockers and pushrods off. I used kerosene here but mine was pretty nasty and I dropped the oil after all my cleanup was done. Adjustment when you assemble it all isn't that bad really. There are a lot of how to's on this and the torque for them is 18-22 ftlbs, I use a 1/4 in torque wrench and use the inlbs side just convert to ftlbs cause it's easy to over do it on these bolts. The valve train may be overkill, but IMHO after sitting that long it's just like starting one on a new build with all of that assembly popcorn dry. Next check your distributor out. If it's corroded under the cap, toss it and get a new one and a new rotor as well. Look over the plug wires, they may have corrosion at either end, boots may be dry rotted, if in doubt, toss it out. Personally I like using cut to fit wires, they make for a lot neater installation and you don't have all the extra wires flopping everywhere. It may also be cheap insurance while you're at it to toss in a new thermostat while the coolant is drained out. Since the coolant is out, check the condition of the radiator, if it's nasty, give it a good clean or a flush. I did mine w Muratic acid. There's a thread on it here is you wanna look it up.After you've changed the oil and are getting ready to fire it up, w/new plugs, distributor cap, wires, oil, lubed up valve train, fresh coolant, there's one more thing if you have the room to do it. Pull the distributor and prime the engine. Turn it over to now at TDC. The balancer should be marked for this if not pop the cap on the distributor and turn it so the rotor points to the no1 spark plugs wire, then pull the distributor out and with a drill, a loooong extension and a 5/16(?) Socket on the oil pump shaft spin it till you see oil come up and on each rocker arm. Then replace the distributor with the rotor pointing the same place and the vacuum advance in the same place as well. Did I mention you'll still have to have the valve covers off? Then pop the valve covers back on. Are we ready to crank yet?? Nope not done yet youngins!! We've still got the fuel system to contend with, whatever's in the fuel tank is way past anything that would burn with a spark. It needs to be pumped out and checked for rot. The one in my Mustang was completely rotten and has to be replaced along w everything in it. So you'll need to check that out good. Need to check that the fuel pump still works, by this time it may be rusted solid, or filled w varnish. The fuel filter will tell you the shape of the fluid in the tank but not the shape of what's going on in the tank. So fuel system in the "back of the bus" will need to be addressed. Up front one piece that I know of more that likely you'll need to replace will be the fuel pressure regulator. It has a diaphragm in it that's more that likely dry rotted. It may still be good, but I'd be prepared on that just in case. Something else that may need attention is the Idle Air Valve. It's located on the side of the throttle body, it may need to be removed, cleaned and make sure it's not frozen up. As far as the rest of the EFI, I'm not sure on that maybe someone else can jump in on that? Check all vacuum lines for dry rot and broken lines, check all wiring for broken or corroded wires? I can't think of anything else??
