1 - 20 of 21 Posts
this is the parts i have left thanks for all the guys who bought stuff
lets see if we cant move the rest of it i might take trades on drag bike stuff/motorcycle stuff or anything else i can use....
dove A 460 2 bolt main ready to go 40 over didnt do it yet due to no pistons block is setup ready to go was run at 30 over 150 bucks
nos pro race fogger lines bent up for the intake i have 475
DSS main stud girdle 150
svo oil pan with rear sump with pick up tube this pan is like new 100
jw wheel needs to be sent back already discussed it with them the lil spacer on it welds cracked they said no problem 40
front and mid plates 100
c6 bradco trans with brake rev pattern billet servo cover 4 gear plant red clutch with more added in pack and 10 inch converter steel stator built for nos with this engine new never run at all 1000 this is a deal i have 700 in the converter itself the trans and converter hasnt even had fluid put in them ..
ill even throw the shifter in for 1000 bucks for all of it
3 stage msd timing retard 80
msd rpm selector switch 30
msd sport comp 5 inch tach internal shift light 80
autometer 2 5/8silver fuel pres gauge 30
b/m pro stick with cable reverse pattern with cable and push button knob 100
ford motorsports valve covers have a few holes in them and a screw on cap was used with vacum pump can always cap them 100
2 1/4 slip on collectors 4 inch 40
3 spoke sweet mfg steering wheel 20
bg fuel pressure reg 4 port plus 80
bg fuel pressure reg 2 port plus 60
c9ve block had a piston come apart block is still usable very rusty from sitin out side 50 bucks
http://s221.photobucket.com/albums/d...lla/?start=all
1 - 20 of 21 Posts
