Cast .30 over pistons,rings,rod, cam and main bearings one main missing hydraulic lifters, cam and springs for a standard rebuild little surface rust from sitting all new $200.00
The cut out for the valves is oval shaped across the center of the pistons long a stock pistons so I don't know if you would say dish or flat top also have oil pump forget to mention
how much for the oil pump? does it have the straight mount for the pick up? I have one with the angle where the pick up goes and cannot use it.
