1 - 3 of 3 Posts
I am into mud drags and I need help picking out a Holley carb. I like the dominator type of carb. And i need help picking out a racing ignition from Mallory.. the cubic inch is 521 and max rpm is 6500-6800
any suggestions?
Super Moderator
We need a little more info to answer your questions. Way too many variables involved to just give you a carb recomendation with just cubic incnes and an RPM range.
What are your cam specs?
What intake manifold do you have?
What is the compression ratio of the motor?
What size is the stall converter if you are running an automatic?
What are the heads?
Let us know and we can give you an answer.
1 - 3 of 3 Posts
