Hello all! Iam working on a 1969 460 with DOVE A heads thread in pedistal type. I installed comp cams Advertised Duration 268/268, Lift .494/.494 . kit number K34-227-4 purchased through summit racing.com. stock length push rods and stock rocker arms. I am on my first engine build and noticed something odd when installed the rocker arms. The nut bottoms out at the bottom of the pedistal with about 5 or so threads protruding from the top, however the rocker arm is still really loose. I installed the rocker arm then the bearing washer then nut. the search feature turned up nothing useful for me. any help would be appreciated.
Second question
the kit came with a timing chain but was told to keep the old timing chain on my motor since they retarded the timing in later years. I couldn't tell a differance between the two and was wondering if anyone had any advice on installing the new or sticking to the old. the top question is more important to me though.
art anchorage alaska....1955 ford f-100
Second question
