Completed C6 to 6R80 swap in my 1972 F-250. 6 gears is a totally different driving experience than 3 speed C6.
6R80 1st gear is 4.17, almost 2x that of C6, and 2 ODs with 6th being 0.69. Cruise 50 mph at 1200 rpm. Lockup converter also helps MPG.
The 6R80 with engine adapter and transfer case adapter is the same length as a long tail c6. Mount moves but driveshafts don't need modification.
Total cost around $5000.
E4OD + converter gets expensive when you need it to hold higher power. 6R is stronger stock and plentiful in the junk yards, for now.
Controller:
US Shift quick 6 is the only option at this time. $1200
Transmission:
Must use a 6R80 with external wiring and controller. Round plug on back right side. Not all 6R80 are like this, for example anything behind a mod motor won't work (4.6, 5.4..)
Most common is a F150 or mustang. F150 can be had in 4x4 flavor although case is the same, maybe output shaft (31 spline) too.
5.0 and 6.2 use mod bell housing. 3.7 TT is different bell/case. These trans are on ebay with mileage from 50k to 300k, for $500 to $1500, torque converter included
I ended up with a trans out of a 2013 F150 5.0 4x4 with 86k for $1200 delivered.
Engine Adapter
2 options, I went with speed gem, and a 5.0 trans. PA had long lead time.
1) Speed Gems $1900, 2" thick, 460 style starter included. Mod bell only
transmissionadapters.com
2) Performance automatic PA68508, $700, some modifications needed. 3.7 bell only
Transfer case adapter:
Advanced adapters has a 6R to atlas adapters, $500. 6R80 TO ATLAS ADAPTER
Atlas is same 6 bolt pattern as many other transfer cases, NP20x, dana 300, BW15xx.
I have a ford NP205 with 31 spline input so no spud shaft needed.
Cooling:
PBH dual o-ring to AN8 adapter. Must use 1/2 lines and decent cooler. I used 26 row plate style OEM Ford 6.0 PSD cooler.
pbhperformance.com
Misc:
Trans has 7 positions, but controller can use 5,6, or 7 position shifter. OEM was a cable, but you can make your own mechanical linkage.
Remote Dipstick, B&M 22200, $250. PA also make one, not as good, not in stock. B&M 22200 B&M Locking Automatic Transmission Dipstick & Tube - Billet Aluminum/Stainless Steel Braided
Adapters
TC adapter need machining for use with NP205
TC uses same 2" spacer. Original 460 flex plate.
Mock-up
Size wise the 6R is similar and should fit with minimal modifications where a C6 was. 6r pan is long and narrow as opposed to the wide pan on C6, hence the C6's need for a long TC adapter for a double cardan style front driveshaft. 6R is slightly heavier than C6 with long iron TC adapter.
Controller:
Transmission:
Engine Adapter
FO2501 "Big Block Ford" 351M/400/429/460 to Ford Modular(6R80) Automatic Transmission
V8, 5.0L, 5.4L, 6R80, 351M, 400, 4R70W, 4R75W, 10R80, 5R110, 4R100, 6R140, Modular Transmission, Ford, Ford V8, Ford Modular, Transmission Swap, Transmission Adapter, Adapter Plate,
Cooling:
PBH 6R80 10R80 Transmission Cooler Adapter Fittings - Power By The Hour
We have released our 6R80 and 10R80 cooler fittings. These fittings are designed to allow replacement of the factory cooler lines for upgraded coolers or in the case of doing a Coyote powertrain swap where a factory cooler can not be used. Our fittings will go in the factory ports on the side...
Misc:
Adapters
Mock-up
