Shortblock is all new, heads, manifold, carb and distributor are used but in good condition.
Ford production 2 bolt block Magnefluxed with o-ringed deck and screw in freeze plugs for possible use with a blower
Ford 460 production crank internally balanced
Eagle H-beam rods w/ARP bolts
JE custom pistons 8 1/2-1 compression for possible blower use
Total Seal rings
Main girdle w/studs
Ford Motorsport SVO Aluminum CJ Heads
ARP head studs
Comp Cams cam, pushrods and roller tip rockers
Mallory distributor
Mallory pro coil
Taylor wires
Scat flexplate
Edelbrock torker II 460 manifold
Holley 800 double pumper w/ manual choke
Ford Motorsport valve covers
Just add an oil pan, pump, pickup and harmonic balancer for your application.
$4000 obo
Cliff Hall
916-487-0978
