1 - 3 of 3 Posts
i have for sale a 460 with c8ve heads block was hot tanked and new cam bearings installed. factory bore was still good nice cross hatches crank was turned .020/.020 with new speed pro performance main and rod bearings rods were reconditioned as well kept stock cast pistons re-ringed them with speed pro rings, fel-pro performance head gaskets. boutght the heaeds built with cam from a guy that had them on a 514 that he blew up heads checked out fine have ferrea 2.19 intake and 1.80 exhaust valves have screw in studs and push rod guides 1.70 roller rockers with hardened 5/16 pushrods have and offenhauser 360* dual port intake 1 carb spacer and holley 850 double pumper carb has a reed cam tm272h hydraulic flat tappet specs in a photo call or text 816-277-5136 thanks
1 - 3 of 3 Posts
