1 - 8 of 8 Posts
D1VE block .030 over, align bored, decked, oil drain holes chamfered
Eagle 6.605 H-Beam rods with ARP2000 bolts
Rotating assembly fully balanced and blue printed.
11.5:1 SRP flat top pistons with top and side coatings.
Ford Motorsports A429 Aluminum Cobra Jet Heads, ported, 2.25 int/1.76 exh.
Crower roller cam - 264/268 Duration @ .050, .664/668 lift
Crower roller lifters
Ford Motorsports 1.73 Roller Rockers with Jessel stud girdle
Ford Motorsports Single Plane High Rise Manifold - port matched to heads
MSD Billet Distributor
Milodon oil pan with Melling high volume oil pump
Engine meticulously put together. Over $1000 in the block alone!
Less than 400 driving miles and about 23 passes.
Ran 10.50s @ 131 in a 3200 lb car, bogging off the line with 850 vac 2nd and a tight converter!
Definitely a low 10 second engine with the right carb and converter.
Excellent pump gas street/strip engine! Still in car. Can see/hear it run.
Stepping up to a bigger engine for next season.
Intake to pan, $5,500
PM or call Rob (516) 799-1147
Atco
Yeah, that was me. The car stumbled off the line due to the vacuum secondary 850 carb. went 10.56 with only a 1.66 60 ft. i'm sure it would have gone 10.30s with a double pumper. I also have video of the run if anyone wants to see it.
Rob
Sweet thought that was the same car. Nice car and it sounded good. It did leave soft though. I was there with the brown truck in my avatar. Good luck with sale.
Atco
Thanks. Yeah, I have the car setup for Nitrous although I haven't run it yet. With more gear, a better carb and higer stall it would definitely go low, low 10s. Sorry, I didn't see your truck run. i was too busy with my car and helping my son as well. he has a '90 fox with a small block he's learing to drive, lol. Your truck looks pretty tough. what size engine are you running? Hopefully we can meet up next year. I should be sporting a 514 then!
This engine has very low miles on it and runs like a champ. I'd really like to get rid of it so I can start working on my next engine. Located on Long Island NY.
$5000 anyone?
1 - 8 of 8 Posts
