1 - 3 of 3 Posts
9.5/ 1 compression, 10 to 15 psi boost, big valve Dove c cast iron heads and block, Race tech custom .032" dished pistons. Blow thru carb on E85. 70cc chambers, Block decked to 005" down
Fresh from machine shop build. I will be using ARP head studs.
Fel-pro 1018 or Cometic MLS both .040 4.500 ?
If the block and heads have a fine enough RU to allow the use of an MLS use them.
If not utilize the 1018 Felpros gaskets.
SJ
used 2b RHP
1 - 3 of 3 Posts
