1 - 3 of 3 Posts
460 bored 30 over stock rods with 190000 psi rod bolts oil mods done to the oil pump hole on the block return holes in the upper high volume oil pump, heads home ported intake to cj size and the exhaust opened to header gasket and egr hump removed, d2ae heads stealth intake kb pistons arp studs in main caps d1az block, clevite bearing stealth intake, crane cam around a 540 lift half to get specs on cam this engine has approx 500 miles on it up grading to a 521. Runs very well 1304 in the quarter in a 4000 lb car very streetable $1700.00 this motor in a fox chssy would run mid 12's. Joe 248-470-5265
1 - 3 of 3 Posts
