1 - 20 of 39 Posts
My bull crap cheap build up...
Car is a 90 hatch (3200lbs race weight with driver)
strange adjustable coil overs front and rear
mini tub
3.73 gears w/spool
thru the floor subs-10 point cage
Trans is a home bru'd C6
TCI 3500 stall with anti-balloing plates added from a local convertor shop and some other lil stuff
Engine
466
stock crank & rods
arp hardware thru-out
L2404 pistons
Cam hydralic flat 280/280 .565/.565 <was in it and gunna use it for now...
Heads are
Dove-c's CJ valves
heavy work on the exhuast, intake clean up & match
Bowl work de-shrouding & cc match
Heads are 66cc
should be around 10-1
Intake is a victor
carb is a AED specialties 750 for the moment will be getting a 1050 dom shortly
Headers are D&D 2" pri 3.5" collector full length fox body hearders
The car has a two stage plate but might not be used until the stock rods come out of it.
I'd like to be bottom 11's on motor or faster does this sound reasonable?
Couple questions
How much tire are you stuffing in those mini tubs? Be sure and tell us what it does run run when you get it out there.
466
This almost the same as my 83 tbird 466 dome piston 13.1 roller cam 654 lift eagle I beam rods 150 or 200 nos victor intake edelbrock heads 75cc clean up ports,c6 transbrake 3500 stall 9 inch,28-10.5 tire looking to go 9 Joe.
Re: 466
9's on the kit?
Re: 466
torinojoe1971 said:
Yes 9s on the spray 10s on motor.
What track to you go to... I live in MI as well south of detroit downriver area... bu tI venture all over milan, norwalk, lapeer, etc...
Some pics from when i got it to what it is now.. has had a few diffrent engine combos
stock 302 with some nitrous
347 with some nitrous
then what it is now
Don't mind my mess of a garage...
Nice Stang 90Hatch.
You going to be at the Fun Ford Weekend at Norwalk?
I met Rick and his awesome 460 based Maverick there last year.
I always look forward to the Ford event at Norwalk(Summit Motorsports Park)
466
90hatch I go to milan lapeer usually. Where down river? I work in southgate, I work for the fire dept there. I live in Farm hills. Looks like some nice work on the car. Do you do any body work on the side? Let me know if you need some parts Joe. If you need a good trans guy I can hook you up and his prices are good.
Discussion Starter #12
511Fox said:
Nice Stang 90Hatch.
I didn't go last year, bu tmy buddy goes every year. Kevin Cody the guy who won the longest wheel stand at the classic BBF n/a in a white capri..
he's the one who kinda finalized me making my mind up to go BBF and not build another windsor.
I'm trying to have the car done here within a few weeks and gunna try and make it down there.
Discussion Starter #13
Re: 466
Wyandotte... I done a lil body work on the side but still don't think I'm good enough to be paid to do stuff for someone.
I do any kinda of mechanical you could think of. From bolt on stuff to diag drive issues on newer stuff.
90hatch,I talked to Kevin Cody a couple years back.
I was at the N.M.R.A race in Columbus real nice guy.I think he has a 540? with C-460 Heads?
Later Mark.
Re: 90hatch,I talked to Kevin Cody a couple years back.
Later Mark.
Mark, if you notice you are typing text in the SUBJECT line which only should be done when you start a new thread..........when you type, only type in the BIG box :wink:
Discussion Starter #16
Later Mark.
yeah he blew that thing up about two weeks ago on the rollers.
He got some engine sponsor from that wheelie contest and is putting together a 600+" mountian motor fo rit should be done here in a month or so..
1 - 20 of 39 Posts
