Hey there guys haven't posted anything for a while but I'm getting close to install of my fresh 468 my concern is my oil pressure my bearings clarence's for rod and mains are .0002" on the mains and rods cam bearings are the narrow ones and new with new hydraulic flat tappet camshaft from Comp cams new 3/8 pushrods and so on the oil pump I'm using is from sealed power supposed to be standard pump my Machinist did oil galley modifications and drilled the outlet of the pump a little larger the color of the pressure relief spring is kinda a reddish brown color to my vision now it all put together I first primed the engine with a speed wrench and with a mechanical oil pressure gauge I got it up to 75 PSI of oil pressure with a cheesy 3/8 drill I got a hair above 75 until the drill crapped out and couldn't do anymore and it don't take very long for that to happen for oil I got Valvoline br1 10w30 granted I got the white Molly assembly lube on all the bearings I didn't even have to rotate the engine to get all the lifters to pump up so should I just put it in my truck and send it or should I start worrying I don't have a drill strong enough to prime the engine more than half a minute so oil in the lifters bleed out over night I wish I had a big *** drill to really get everything oiled up good sorta speak. Any help with this or ideas or again I'm I bing paranoid? Oh it's a rear sump system. Here's a couple pics.
